16 years agoAbout the address setting
Hi all: I'm a new worker on NIOS,I'm using a CycloneIII starter board and followed a sopc class.I have some basic questions about NIOS and SOPC. First:My board have a CFI flash and a SSRAM...
16 years agoThank you xiwen :)
Today I tried to burn the flash with Nios II flash programmer,I specified my .sof file and the offset 0x20000,then programm.I got the message below:# !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd D:/Copy_of_cosmic_2009/software/simple_socket_server_6/Debug # Creating .flash file for the FPGA configuration "$SOPC_KIT_NIOS2/bin/sof2flash" --offset=0x20000 --input="D:/Copy_of_cosmic_2009 /cosmic_top.sof" --output="cosmic_top.flash" Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert D:/Copy_of_cosmic_2009/cosmic_t op.sof cosmic_top.rbf Info: Using INI file c:/altera/81/quartus/bin/quartus.ini Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 76 megabytes Info: Processing ended: Fri Feb 26 11:58:16 2010 Info: Elapsed time: 00:00:01 Info: Total CPU time (on all processors): 00:00:00 # Programming flash with the FPGA configuration "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x01000000 --sidp=0x02203d48 --id=2052607805 --timestamp=1239120610 --instance=0 "cosmic_top.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x02203D48: verified : Checksumming existing contents 00020000 : Reading existing contents 00040000 : Reading existing contents 00060000 : Reading existing contents 00080000 : Reading existing contents 000A0000 : Reading existing contents 000C0000 : Reading existing contents Checksummed/read 67kB in 1.9s 00020000 ( 0%): Erasing 00040000 (16%): Erasing 00060000 (33%): Erasing 00080000 (50%): Erasing 000A0000 (66%): Erasing 000C0000 (83%): Erasing Erased 768kB in 5.0s (153.6kB/s) 00020000 ( 0%): Programming 00040000 (16%): Programming 00060000 (33%): Programming 00080000 (50%): Programming 000A0000 (66%): Programming 000C0000 (83%): Programming Programmed 702KB +66KB in 28.2s (27.2KB/s) Device contents checksummed OK Leaving target processor paused Seems actually the GUI just use two commands,one is for generating a flash file,and one is for programming the flash.The problem is after I switch off and on, I tried to run my software on the board but failed, seems like I didn't really burn the flash successfully.Are there any problems about the two commands?
