20 years agoabout sdram addrss/data bus shared
hi all: In tne altera reference design, the SDRAM not share address/data bus with flash, sram, lan chip. But in my design I shared sdaram address/data bus with flash to reduce IO pins...
20 years ago --- Quote Start --- [<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14247)</div> --- Quote End --- sure, setup nios2 to reset from cfi flash in sopc builder, and generate. setup your fpga to configure from AS, epcs in quartusII and compile . the config mode pins of fpga should be wired to epcs (standard or fast) config mode . then you can program the sof to epcs, and zImage to cfi flash, as in step7 in the buildroot guide,
# Creating .flash file for the FPGA configuration
sof2flash --epcs --input=your_system.sof --output=standard.flash# Programming flash with the FPGA configuration
nios2-flash-programmer --epcs --base=0x02200000 standard.flash# Creating .flash file for the project
elf2flash --base=0x00000000 --end=0xffffff --reset=0x0 --input=zImage --output=ext_flash.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec# Programming flash with the project
nios2-flash-programmer --base=0x00000000 ext_flash.flash <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14251)</div> --- Quote End --- hi hippo: Thank you for you reply.But I still have some doubt. If I use quartus programer burn the cpu.pof in to EPCS4 using AS mode by jtag download cable.Do I need exec following step? # Creating .flash file for the FPGA configuration sof2flash --epcs --input=your_system.sof --output=standard.flash# Programming flash with the FPGA configuration nios2-flash-programmer --epcs --base=0x02200000 standard.flash Because the nios2 cpu.pof have already exist the EPCS4.When I pown on the customer board , the FPGA will download the cpu.pof from the EPCS4 ,then the nios2 cpu will reset from the cfi flash address 0x00000000. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14264)</div> --- Quote End --- The two methods do the same thing. So you can just use quartusII programmer for pof. there is no need to use sof2flash again.
