20 years agoAbout Reduced RAM and flash
hi all:
i'd like to make a cyclone niosII board,i want to known the smallest ram and flash capapicity.And where need i revised the uClinux source. THANKS My english is bad,sorry!3 Replies
it will depend on your application. If you use initramfs, a possible configuration could be 4 MByte CFI Flash 16 MByte DDR It is probably a good idea to try out everything on the Altera Eval Brd first. - Altera_Forum
consider using the EPCS device for flash instead of External flash - it can hold quite a bit!
The other person is correct it will depend on your application. But the minimum size you can get away with is 4MB for flash (2MB for the kernel, 2MB for shell, utilities and your applications) and 8MB for SDRAM. If your application is large or you are going to manipulate or transfer large quantities of data 8MB of SDRAM is probably not going to be enough for uClinux.
