21 years agoabout .rbf option
In the device option I select the .rbf option to generate a raw binary file,but after compile that, the .sof can't be download into the FPGA. the error info: Error: CONF_DONE pin failed to ...
21 years agoI have such trouble when in Quartus in Select Device options wath selected incorrect device. Check your kit - some of them are with ES devices. 1s10ES for example. If you try to programm it with file generated for 1S10 device you got error.
Check the options.
