21 years agoabout .rbf can't be config to FPGA
Hi all I have programed the .rbf file generated by QuartusII into Flash (0x600000,statix 1S10 board). but, the config contoller can't boot the .rbf to FPGA when power on. who can tell me wh...
21 years agoHello ffone13,
I think the English of both of us is not the best. This makes it very hard to understand what the other person means. But we will find a solution http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif 1. You said that a configuration from Quartus II is possible; does that mean that your design is also running when you configure the FPGA in this way? 2. Did you test your design with the Nios II IDE? Is it possible to program the Flash via "Flash Programmer¡" of the IDE? I mean if this is not working correctly than it is also impossible to program the flash without the IDE. What do you think about this? 3. For creating an rbf the makeprogfile utility is used. This little software can be used by Quartus II or Nios II IDE. Bye, niosIIuser PS: Thanks for completing your post.
