21 years agoabout .rbf can't be config to FPGA
Hi all I have programed the .rbf file generated by QuartusII into Flash (0x600000,statix 1S10 board). but, the config contoller can't boot the .rbf to FPGA when power on. who can tell me wh...
21 years agohello niosIIuser
If you say that my English level is bad directly, I will feel better some. 1. of course, configure the FPGA via JTAG from Quartus II. 2. I want to use .rbf file directly programmed into Flash,not use the Flash Programmer from NIOS IDE. 3. I didn't alter the EPM config file. It's OK. the .rbf file is generated by QuartusII not NIOS IDE. It's the raw binary file that somebody think it can be writed to Flash like .bin file directly. and I think so. but when I write the configuration file (hardware image).rbf to Flash (0x600000 user section) by software not from nios IDE Flash Programmer, it failed when power on. I have finished the corresponding topic,but the topic have been flood by the ground sea.there are too many topics ...
