21 years agoabout .rbf can't be config to FPGA
Hi all I have programed the .rbf file generated by QuartusII into Flash (0x600000,statix 1S10 board). but, the config contoller can't boot the .rbf to FPGA when power on. who can tell me wh...
21 years agoHello ffone13,
I’m sorry but I don’t understand your problem exactly. The reason could be that my English is not the best – I should improve this in the future http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Here are my questions which will help me to understand your problem. Please answer these one after one. 1. Is a configuration of the FPGA via JTAG from Quartus II possible? 2. What do you mean with .rbf option? 3. Did you change the programming of the configuration CPLD (EPM7128)? Just to clarify .rbf: A “Raw Binary File” will be created automatically when you use the “Flash Programmer” from the Nios II IDE. The Software is turning a .sof into .rbf for programming the flash. <div class='quotetop'>QUOTE </div> --- Quote Start --- Yes, I have said it's the hardware problem.[/b] --- Quote End --- Please post the answer to the corresponding topic. Bye, niosIIuser
