21 years agoabout .rbf can't be config to FPGA
Hi all I have programed the .rbf file generated by QuartusII into Flash (0x600000,statix 1S10 board). but, the config contoller can't boot the .rbf to FPGA when power on. who can tell me wh...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- the hardware and software(QII 4.0+sp1) are standard[/b] --- Quote End --- Normally it is good to use the actual software (Quartus II 4.2)? Which Nios version are you using? So you are not able to configure the FPGA with your sof-File? But Quartus II is detecting your device? Did you change the programming of the configuration CPLD (EPM7128)? <div class='quotetop'>QUOTE </div> --- Quote Start --- BTW: I have settled the Flash on the S80 board due to kindhearted man's help. and your mention is custom board that we made also dealed with. It caused when we solder the flash to board.[/b] --- Quote End --- Is that the explanation for about flash (http://www.niosforum.com/forum/index.php?act=st&f=2&t=667)?
