21 years agoABOUT RAM
I try to use a SDRAM on a custom board instead of SRAM. Since a SDRAM consumes too many pins, I'd like to share data bus with other peripherals, such as LAN, USB. Can it be achieved? ...
21 years agoThe Altera-provided SDRAM controller should support connections a tri-state bridge. Just look for the "Share pins via TriState Bridge" check box in the Wizard when adding a new instance of SDRAM controller.
Cheers, - slacker
