21 years agoabout programable UART Baudrate
the readme.txt of the board_diag show that: * - UART test * Tests UART functionality for the UART defined as STDOUT. * * Currently, only tested on the JTAG UART device. the component ...
21 years agoffone13,
There is an ioctl call to set the baud rate etc for the UART. If you look in the manual for the UART n2cpu_nii51010.pdf and look under the software programming model there is a section in here on ioctl which is where you should start.
