21 years agoabout niosII IDE system library property,
i am confused about it. when: the reset address is in ext_ram,linker script setting is: .text onchip_ram .rodata ext_flash .rwdata ext_ram it run ok. but when down...
21 years agojesse
yes i am using auto-generated linker script. i only test it. i know if these address setting to volatile memoty,it's ok. i wonder why the .rodata is in ext_flash when the reset address is in ext_ram.it run ok? and when the reset address is in ext_flash it failed? your meaning .rodata can't put into ext_flash? but it's opposite to my testing.
