20 years ago
about nios2 terminal control question
HI all:
When I run a application program by terminal, I cannot quit the application function
or come back terminal.For example ,after I run pining application,i unable perform
other command. Please tell me what should I solve this problem.Thanks a lot.
    Hi alex,
    If I understand you well! you can try "Ctrl +C" !
    --- Quote Start ---
    originally posted by feiwu@Nov 10 2005, 02:17 AM
    hi alex,
    if i understand you well! you can try "ctrl +c" !
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10888)
    --- quote end ---
    --- Quote End ---
    hi
    After I try ctrl+c, i exit terminal. when i logo in system angain,My system still running previously program.
    alex824,
    Log in through your ethernet terminal. Then do
    $ ps -a
    This will give you the process id of all applications currently running.
    Then do
    $ kill -9 "pid number"
    Without the quotes, replace pid number with the actual number of your process id.
    Doug
