20 years agoabout NET-SNMP port in nios2-uclinux
Hi all: I want run a snmp agent in my product. My product use nios2 cpu with nios2 uclinux 2.6. What should I port NET-SNMP in nios2 uclinux?
20 years agoI'm not sure how hard it is to do under cygwin...
I *think* you should be able to run under linux:# ./configure --target=nios2-linux OR# ./configure --host=nios2-linux OR under cygwin I think it is:# ./configure --target=nios2-elf OR# ./configure --host=nios2-elf You probably have to add nios2 information to the config.sub file in the section which begins with: case $basic_machine in then you can make and make install as normal. But I never had much succes using cygwin, so if you have the chance get a linux machine with marc's crosscompiler (http://scorpius.homelinux.org/~marc/nios2.html)!!
