20 years agoabout memory problem for uclinux....
hi all I have upload a music file(xxx.wav,about 700kB ) to uclinux from my PC ,and I got very long error messages on uClinux . such as following: it seems memory not enough.............. anyone ...
20 years ago --- Quote Start --- originally posted by hippo@May 26 2006, 10:09 AM maybe you can try init+sash of uclinux-dist instead of all in busybox.
it should save some memory usage.
http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist)
you may also try nfs root. (but i didn't test that yet)
or, the hardware approach, check if you can replace the sdram chip to 32mb, (ie 16mx16).
it has the same pins out, but address a12. you can check if there is a pcb trace reserved for a12. or you can find some spare pin out of 2c35.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15587)
--- quote end ---
--- Quote End --- Hi hippo : Thanks for your reply, I think NFS maybe the effective way,I will do it quickly.If I've done it, I will let you know! Regards!
