20 years agoabout memory problem for uclinux....
hi all I have upload a music file(xxx.wav,about 700kB ) to uclinux from my PC ,and I got very long error messages on uClinux . such as following: it seems memory not enough.............. anyone ...
20 years ago --- Quote Start --- originally posted by hippo@Apr 26 2006, 07:39 AM you have very few memory available.
you should use the 4m cfi flash first.
spansion was previously a joint venture of amd and fujitsu.
[* ] support for amd/fujitsu flash chips
you can use it as a jffs2 drive.
you can mount it as rootfs, with kernel command line "root=/dev/mtdblock0", and disable initramfs. this will save some memory usage.
there is new option,
in kernel config for higher than 2.6.11,
general setup -->
[*] configure standard kernel features (for small systems) --->
[ ] enable full-sized data structures for core
no in this option will reduce kernel data structure size.
using sd is ok, but it is slow.
using usb disk on isp1362 ? working ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14709)
--- quote end ---
--- Quote End --- hi hippo may i select same options with buildboot guide# point 8(using cfi-flash) ? i have a question , because i don't know how to use kernel command line with "root=/dev/mtdblock0" and disable inutramfs . so ... where should i be done? thx in advance !
