20 years ago
About host file system
I used the altera host file system to open a file .mp3,, is this a legal operation or not?
if it is legal then why [[FILE *hostfile =fopen ("/mnt/host/song.mp3","rb");]] return NULL!!
can any one tell me the exact syntax to access the file and where exactly should the mp3 file"song.mp3" exist?
thanks
    @xiaban
    Could you please tell me exactly how did you manage to read a file from the PC and store it on the onchip memory? Could you share some code please too?
    Host file system read data from PC to buffer, and I read data from buffer and write to on-chip memory.
    thanks for ur fast answer ..
    1. but doesn't this only work in debug mode ..? i need to transfer the image to onchip .. and when its done let my own verilog modules handle the processing ..
    2. is this correct?
    void* ptr = (void*) On_chip_base_address
    then i use fread to write to on_chip?
    i am new to this, could you please share some code which handles reading /writing?
    Yes ,it works only in debug mode.
    Some codes as following:
    fread(buffer,1, 1, fp_bin); //read
    IOWR(MEMORY_BASE,0,buffer[0]); //write
    Thanks .. :)
    but it seems that my code seems stuck at fopen for no obvious reason ..
    the host file based system is enabled .. the file is "/mnt/host/filename.bmp" and placed in the same directory as the main c file ..
    in debug .. fp always returns null
