21 years agoabout flash2dat
Hello I'm suyo.
I hava a question about flash2dat utility. flash2dat executes the following command. flash2dat --infile=ext_flash.flash --outfile=ext_flash.dat --width=8|16|32|64|128 --base=0x0 --end=0xFFF --pad=1 --create-lines=1 Which address will the base address and the end address should set? Design is using standard. Regars, suyoNo RepliesBe the first to reply
