21 years agoAbout external SRAM
Hi, I have problems with my NIOS and external SRAM. any of your help are appreciated. the case is as following: I have a board built of my own, the board contain a Stratix chip EP1S20F7...
21 years agofirst check if your hardware is ok
if you use the "onchip memory program", try to access the external sram from either - "memory view in the debugger", you can write and read to your external memory from this window, - access your external sram with some small testcode (write to sram address and read back) if your hardware is ok, check the settings in SOPC Builder "Nios II more CPU Settings" and system libray properties
