21 years agoAbout external SRAM
Hi, I have problems with my NIOS and external SRAM. any of your help are appreciated. the case is as following: I have a board built of my own, the board contain a Stratix chip EP1S20F7...
21 years agoYes, if I starting from a simple nios2 system with onchip memory, I can debug and trace my application. there is an arrow point to the 1st line of my source C code when I start debugging. But if run the same application in my nios2 system with offchip memory, then I can not debug and trace my application, all "Step Into, Step Over..." menus are grayed and not active, there is no any arrow point to my C source code.
So, I think there sould be some wrong in my system with offchip memory. But I still do not even have a clue of where the wrong is. Could you give any further advices. Thank you. Gong Xuechun
