about DSP_stratixII_2s60_ES's schematic
in the ..\nios2_1.01\examples catalogue there is DSP_stratixII_2s60_ES example,it port the nios for the dsp board.but i can only find nios_2s60_board_schematic.pdf that is not design for DSP_stratixII_2s60_ES .The pins is not consistent with DSP_stratixII_2s60_ES .
who can show me where to find schematic.pdf for DSP_stratixII_2s60_ES ? thank u! best regard! ffone4 Replies
If you have the software for the Stratix II DSP Kit (difficult as I don't believe it's released...yet), you should be able to find it in *that* kit's installation directory *not* in the Nios II installation directory...
The DSP board and kit details do not belong and are not part of the Nios II development kit. The example designs that run on Nios II on the Stratix II DSP board are... Hope that helps. - slacker - Altera_Forum
I'm told that the DSP board materials, including schematic, will be posted on the altera.com website soon - probably within a week or two.
expecting! by the way,do you port niosII to S80 dsp board?there are some difficulties for doing it especially with flash and ssram.
Hi ff113,
Sorry, no, we have not (to my knowledge) done Nios work on that board. You should be able to to anything on-chip that you desire quite easliy (all through JTAG). For the memory its good old-fashioned board bring up work to get the IOs and timing correct.
