21 years agoAbout DMA and user logic ,help!
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif Hello. I have a DMA controller and LCD controller in my sopc system. LCD controller is adder to system as the user logic....
21 years agoHello yks,
To answer your questions. 1. No, The code that I showed only needs to show where the read address is located( Like the array holding your image) 2. My code is a little convoluted but essentially I am passing a structure to vga_dma_done called vga_dma_done_context. This structure has an element that I am defining as the array for my_isr_context, which is the address that I want my function to implement when the fuction vga_dma_done is called, which is really just the completion of the DMA access, which is alt_dma_txchan_done. I know that sounds a little "wordy"; But reply if you have more questions and I would be glad to help... Really, what is happening is that it is hard to get real-time control while the DMA function is running, that is why I think it is hard to implement an ISR. I tried earlier this year to measure performance of this system with timestamps and I had a real mess. Of course, I may have self-inflicted harm on myself when trying to make those measurements. -Baycool
