22 years agoAbout CS8900
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif Hi,all,
when I tried to add cs8900 in SOPC Builder onto my dev board of APEX20KE,I thought I paid off.But when it came to trying to compile and execute a demo program,the screen showed some error message like this:(The demo I use is hello_plugs.c in the directory of cpu_sdk/src/) nios-run: Terminal mode (Control-C exits) ----------------------------------------- spurious interrupt number: 0000001c# 8B553048 cs8900_32 + In fact,when I added the peripheral onto our board by plugging it on the dev board,the PC showed the linking has been linked. That may meaned my device without problems.Then I tried to compile the demo of hello_plugs.c.The step passed normally. But when I attempted to run it on the board by typing nr hello_plugs.srec ,the error message appeared.Could you please tell me why this happend? Many Thanks! Don http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif2 Replies
Ohhhh... I seem to remember this. Let me look. You might want to see what interrupt is at 0000001c
Back in a bit... Kerri - Altera_Forum
OK, a note from an old problem report:
... at least you, the designer, will now have some clue that you should disable that interrupt in SOPC Builder, or modify nios_setup.s, as needed. **** Can you disable the interrupt that is appearing?
