21 years agoabout component made by user logic
hello, anyone encounter this problem that a component made by user logic can't run with nios system that has comprised ram and flash and so on? who can give me some suggesti...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Yeah, I have chosen all the possible optimizations for the project. Although the Nios and peripherals run in asynchoronizing mode, only one system clock be input here.[/b] --- Quote End --- I'm a little confused about that. So you don't run your custom hardware at the same clock? If that's the case then you need to synchronize the interface to your hardware so that the data gets across properly. I will need some more information about the system now (NIOS and the custom hardware) because I'm drawing at straws here.
