21 years agoabout component made by user logic
hello, anyone encounter this problem that a component made by user logic can't run with nios system that has comprised ram and flash and so on? who can give me some suggesti...
21 years agoPerhaps I should describe the problem clearly.
Firstly, the Nios could run well before I create a peripheral. Secondly, the Nios could run well also when I add an IUL which is used to link the Nios and peripheral. Now the peripheral is not embedded on synthesis. Timing is correct. However, the Nios runs down if I compile the Nios and peripheral togather. No response when I debug/run the program on Nios. Even "hello world" could not be run on it. I launch FS2 console window and find such instructions of "ldhio gp -16536" at the beginning. I think the point must break down. I use IDE to debug the codes. Need I make a file of changing the debug options? Thanks.
