20 years agoabout cfi-flash for DE2 board....
hi hippo my cif-flash addr is 0x0800000. Dose i need to change my cfi-flash addr mapping MTD partition of altera.c ? Thx !
20 years agohi hippo
I have disable kernel path to empty and rebuild kernel . My new kernel size reduce much more that around is 587KB. But ,i can not execute command on uclinux. <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 rootfstype=jffs2 PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6768k/8192k RAM, 0k/0k ROM (1185k kernel code, 144k data) Mount-cache hash table entries: 512 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub JFFS2 version 2.2. (NAND) © 2001-2003 Red Hat, Inc. io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80481120 (irq = 1) is a jtag_uart Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 1 MTD partitions on "Altera NDK flash (AMD)": 0x00000000-0x00400000 : "jffs2" usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362_hc_reset: isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362-hcd isp1362-hcd: irq 4, io mem 0x804810d0 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 4 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. VFS: Mounted root (jffs2 filesystem) readonly. Freeing unused kernel memory: 44k freed (0x938000 - 0x942000) Warning: unable to open an initial console. Kernel panic - not syncing: No init found. Try passing init= option to kernel.[/b] --- Quote End --- Do you know why can not find init ? Thx !
