20 years agoabout cfi-flash for DE2 board....
hi hippo my cif-flash addr is 0x0800000. Dose i need to change my cfi-flash addr mapping MTD partition of altera.c ? Thx !
20 years ago --- Quote Start --- originally posted by hippo@May 29 2006, 08:21 PM <div class='quotetop'>quote
--- quote end ---
--- quote start ---
finally,i have proplem about cpu start addr, when i have changed sdram addr in sopc builer,and how to edit cpu start addr in kernel configure ? --- Quote End --- You need to make clean, and make hwselect. The hwselect script will update cpu start address linkage in kernel. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15672)</div> [/b] --- Quote End --- hi hippo I have already done according to what you said("make clean","make hwselect".....) Finally, the same problem apperas,again. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Why I always meet the same problem ? and which place i didn't set and miss ? so far, i directly download zImage to sdram under sdk shell. i have compiled my project and generated new up4.rbf on QII. i have two guestions about how to program epcs serial flash ?(storing hw config and zImge): Q1: how to download my up4.rbf to epcs and use nios2-flash-programmer under sdk shell ? Q2:Does i need to change format of my zImage ? how to download my zImage to epcs and give spectify addr with using nios2- flash-programmer commad ? can you give me a example how to use nios2-flash-programmer command ? THx !
