20 years ago
About C++ compiler problem
hi hippo
I can't use "nios-linux-uclibc-cpp" command to compile my app program for C++.
and i can find "nios-liuux-uclibc-cpp" compiler in /home/opt/nios2/bin dir.
why ?
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
[faye@localhost wsola]$ nios2-linux-uclibc-cpp main.cpp -o main -elf2flt
nios2-linux-uclibc-cpp: main.cpp: C++ compiler not installed on this system[/b]
--- Quote End ---
THX !
    --- Quote Start ---
    originally posted by jay_1025@Jun 7 2006, 12:33 AM
    hi hippo
    i can&#39;t use "nios-linux-uclibc-cpp" command to compile my app program for c++.
    why ?
    <div class='quotetop'>quote
    --- quote end ---
    --- quote start ---
    nios2-linux-uclibc-cpp: main.cpp: c++ compiler not installed on this system
    --- Quote End ---
    THX !
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15970)</div>
    [/b]
    --- Quote End ---
    cpp is c preprocess.
    The compiler is g++.
    But the c++ library stdc++ still has problem.
    hi hippo
    So, i can&#39;t use C++ compiler under uClinux-dist-test.
    Can i use C++ compiler under linux-2.6.16.1(buildroot)?
    Thx !
    --- Quote Start ---
    originally posted by jay_1025@Jun 7 2006, 12:50 PM
    hi hippo
    so, i can&#39;t use c++ compiler under uclinux-dist-test.
    can i use c++ compiler under linux-2.6.16.1(buildroot)?
    thx !
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15980)
    --- quote end ---
    --- Quote End ---
    No. They are the same compiler.
    --- Quote Start ---
    originally posted by hippo+jun 7 2006, 12:06 am--><div class='quotetop'>quote (hippo @ jun 7 2006, 12:06 am)</div>
    --- quote start ---
    <!--quotebegin-jay_1025@Jun 7 2006, 12:50 PM
    hi hippo
    thx !
    --- quote end ---
    --- Quote End ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15981)</div>
    [/b]
    --- Quote End ---
    hi hippo
    In other word, i can only write app program in C language.
    Do you konw how to solve this problem for C++ compiler?
    Thx !
    It is difficult. And I am not an expert of c++.
    The compiler should be OK.
    But the stdc++ does not work.
    It hangs when enter c++ function.
    There are other solutions, such as STLport or uclibc++ .
    But I don&#39;t know how to use them.
