21 years agoAbout a err message in NiosII
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif hi all, When I applied ByteBlasterII to download my program into the dev board from Altera, something internal error i...
21 years agoas for your first question,i have encountered the same.i think it is just a warning,in that i have heared that it was past issue in nios2 ide form a engineer .in the other hand ,you can ignore the problem instead of using the "USB Blaster revision B cable or another supported cable".
about your second issue,"nios2-terminal: exiting due to I/O error communicating with target:,it is possbile that your system is wrong. it is all my opinion.
