20 years agoa weird issue
Hi all, I encountered a weird issue that I enabled one PIO interrupt by using: alt_irq_register(STROBE_PIO_IRQ, edge_capture_ptr, command_receive_interrupt); STROBE_PIO_IR...
20 years agojust an update.
I have 5 interrupts, so I tried to modify the interrupt level, When I tried: module interrupt level lcd controller 0 video_0 1 video_1 2 strobe 3 jtag_uart 4 the strobe interrupt can't enable due to the reason above. when I tried: module interrupt level lcd controller 0 video_0 1 video_1 2 strobe 4 jtag_uart 6 the video_1 interrupt can't enable due to the reason above. when I tried: module interrupt level lcd controller 0 video_0 2 video_1 3 strobe 5 jtag_uart 7 the video_1 and jtag_uart interrupts can't enable due to the reason above. when I tried: module interrupt level lcd controller 0 video_0 2 video_1 4 strobe 6 jtag_uart 8 All the interrupts are enabled and everything is OK. I think it's a very wierd issue, maybe someone can help me with the interrupt architecture of NiosII. Do anyone know about that in which condition the ienable register will be modified or can't be wrote? Thanks any help, David
