20 years ago
a weird issue
Hi all,
I encountered a weird issue that I enabled one PIO interrupt by using:
alt_irq_register(STROBE_PIO_IRQ, edge_capture_ptr, command_receive_interrupt);
STROBE_PIO_IRQ equals to 3
after calling alt_irq_register, the ienable register doesn't change its value to enable STROBE_PIO_IRQ.
So, I tried to find what was the problem, then I step into alt_irq_register routine, and found the problem, see the following assembly code:
wrctl ienable, r2
before excuting this instruction, I can see that the value stored in r2 register is 0x1f and ienable = 0x17, but after excuting this instruction the ienable remained the original value of 0x17.
It&#39;s a very weird problem, anyone help? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
best regards,
David
    just an update.
    I have 5 interrupts, so I tried to modify the interrupt level,
    When I tried:
    module interrupt level
    lcd controller 0
    video_0 1
    video_1 2
    strobe 3
    jtag_uart 4
    the strobe interrupt can&#39;t enable due to the reason above.
    when I tried:
    lcd controller 0
    video_0 1
    video_1 2
    strobe 4
    jtag_uart 6
    the video_1 interrupt can&#39;t enable due to the reason above.
    when I tried:
    lcd controller 0
    video_0 2
    video_1 3
    strobe 5
    jtag_uart 7
    the video_1 and jtag_uart interrupts can&#39;t enable due to the reason above.
    when I tried:
    lcd controller 0
    video_0 2
    video_1 4
    strobe 6
    jtag_uart 8
    All the interrupts are enabled and everything is OK.
    I think it&#39;s a very wierd issue, maybe someone can help me with the interrupt architecture of NiosII. Do anyone know about that in which condition the ienable register will be modified or can&#39;t be wrote?
    Thanks any help,
    David
    The ienable register only has a bit for each interrupt actually connected to the Nios II.
    For example, if you have IRQ 0 and IRQ 1, the ienable register only really has registers
    for bit 0 and bit 1 of the ienable. The other bits of the ienable always read as zero.
    So, it is possible that you don&#39;t have the interrupts properly connected to the CPU.
    Hi James,
    I understand what you mean...
    Maybe you mistook my meaning, I&#39;m very sure that I have connected all the interrupts....
    As you can see, when I changed the interrupts&#39; level, different interrupts can&#39;t be enabled, sometimes, even if the jtag_uart interrupt can&#39;t be enabled.
    Thanks for your reply,
    David
    Hi James,
    Maybe you are right...
    But all my interrupts can be assigned a interrupt level in SOPC Build, so I&#39;m confused...
    In which case, the interrupts don&#39;t connect to the CPU?
    David,
    This may look loke an unrelated question, but I ask it anyway : do you use the Fast core with data cache??
    I had some issues with interrupts and the fast core in the past. No-one had any interest in diving into the problem with me, and I had to go to the economic core version. Although the economic core looks better for my system in terms of interrupt latency.
    So if you use the fast core, I wish you good luck.
    Stefaan
    Hi David,
    Maybe you should move to uClinux.
    Though it take some time to learn module programming on Linux, you get more in return. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    You should read about interrupt on the book "Linux device driver 3rd ed.". You can download it from the net.
