21 years ago
A very strange problem~
I have testing on another board~stratix EP1S10
And succeed in building the uClinux on this board
/etc/issue              www.microtronix.com               July 2004
                   Welcome to Linux on the Nios II
(none) login: Linux version 2.6.9-uc0 (JustinYan@JustinYan) (gcc version 3.4.1 (
Altera Nios II 1.1 b137))# 1 Tue Jul 19 14:48:58 PST 2005
uClinux/Nios II
Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 128 (order: 7, 2048 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 14396k/16384k RAM, 0k/0k ROM (1472k kernel code, 323k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
Serial: JTAG UART driver $Revision: 1.3 $
ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 66667 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:
ed:0a:03:24
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=2
Using anticipatory io scheduler
Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank
 Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
0x00600000-0x00700000 : "User configuration"
0x00700000-0x00800000 : "safe configuration"
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 52k freed (0x11a2000 - 0x11ae000)
init: exec rc failed
init: Booting to single user mode.
init: exec of single user shell failed
(none) login: nios
Password:
Login incorrect
To login using
username: nios
password:uClinux (with the capitalization of the “C)
I think this username and password are correct, but can't login,don't know why.
Can anyone help me?
Thank you!
Regards!
Justin
    It seems, that your linux can't find a shell. Is /bin/sh in the filesystem project?
    Hi:
    Thank you very much~!
    The problem is what you say, no /bin/sh to install...
    Now the problem is fixed~!
    Thank you!
    Regards!
    Justin
    Hi~
    I have almost the same problem with you.
    Could you teach me how you solve this problem.
    How to install it bin/sh
