20 years agoa strange problem, pls help me out
first some descriptions of my board:
quartus: 5.1 nios2: 5.1 nios2 cpu: nios/f with data cache uClinux: derived from nioswiki.jot.com everthing of the uClinux seems to be ok because I have done many verifications on it and nothing is wrong. But when I run a user application including the following codes, the uClinux automatically reboot:#define writew(b,addr) __builtin_sthio ((void*)addr,b)# define readw(addr) __builtin_ldhuio ((void*)addr)
for(i=0;i<100;i++)
daq_status0=readw(STATUS2_BASE)&1;
fselect_counter=readw(STATUS1_BASE);
while( daq_status0==(readw(STATUS2_BASE)&1) )
} /* STATUS1_BASE and STATUS2_BASE are the address of the registers in my user logic outside the nios2 cpu and are mapped to a flash-like space of the nios2 cpu. I have verified that it's the above codes that make the uClinux system automatically reboot when I run it. I generate the cross compiler according to "http://nioswiki.jot.com/WikiHome/OperatingSystems/BinaryToolchain" and compile my user application by such gcc command: nios2-linux-uclibc-gcc hello.c -o hello -elf2flt */ then i changed my codes to the following: #define writew(b,addr) __builtin_sthio ((void*)addr,b)# define readw(addr) __builtin_ldhuio ((void*)addr)
for(i=0;i<100;i++)
delay(1,1);
delay(1,1);
delay(1,1);
void delay(int loop1, int loop2)
int i,j,k;
for(i=0;i<loop1;i++)
for(j=0;j<loop2;j++)
k=j;
} Then my application can function correctly in most times, but there is still a small probability to let the system reboot automatically. My have made a lot of effort to do with the problem, but I can't still get rid of it! can someone give me some hint or suggestion about the problem?No RepliesBe the first to reply
