21 years ago
a strange problem about quartusII 5.0
I construct a sopc project in quartusII 4.1, and I can run any example on my board!
but I contruct the same sopc project in quarutsII 5.0, when I run the hello_led project in niosII IDE, the console give me such message:
Processor is already paused
Reading System ID at address 0x00301838: verified
Downloading 00200020 ( 0%)
Downloaded 1KB in 0.0s
Verifying 00200020 ( 0%)
Verified OK
Leaving target processor paused
but when I run the hello_world project in niosII IDE, the console display:
Downloading 00210000 (72%)
Downloaded 89KB in 2.3s (38.6KB/s)
Verify failed
why quarutsII 5.0 can not work??
    I think it is due to your SOPC system.
    The problem appears when the cpu cannot work. And there are two reason may cause the result: One is the system you creat, mabye something wrong is with your system;and another may be that your FPGA configuration is destroyed, a new configuration is needed.
    I use niosII 5.0 and quartusII 5.0!
    but hello_led is successful, and hello_world can not work!
    it is very strange !!!!!!!!!
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    it is very strange !!!!!!!!![/b]
    --- Quote End ---
    It is because the file size of them.
    What type of dowload cable do you use?
    I find Byteblaster II will occur similar errors. Please refe to:run as hardware error (http://www.niosforum.com/forum/index.php?act=st&f=2&t=2099)
    yes ,I use byteblasterII!
    but when I use quartusII4.1 and niosII1.0, everything is ok!
    is there a bug in niosII 5.0?
