20 years agoa simple application error
dear all,
I do according to hippo,when i do a simple application program in the last,and insert to uclinux,when i run "make": then the error found: ========================== find . -depth -type d | xargs rmdir > /dev/null 2>&1 || exit 0 Making symlinks in include/ Making include/c++ symlink to compiler c++ includes make[1]: Leaving directory `/home/fzh/uClinux-dist-test/include' make[1]: Entering directory `/home/fzh/uClinux-dist-test/user' for i in apphello busybox games inetd init sash telnetd /home/fzh/uClinux-dist-test/vendors/Altera/nios2nommu/. /home/fzh/uClinux-dist-test/prop; do if [ -d $i ]; then touch $i/.sgbuilt_user; make -C $i || exit $? ; fi; done touch: 正在创建目录 ‘apphello/.sgbuilt_user’: 权限不够 make[2]: Entering directory `/home/fzh/uClinux-dist-test/user/apphello' nios2-linux-uclibc-gcc -Os -g -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/fzh/uClinux-dist-test -fno-builtin -I. -c -o apphello.o apphello.c Assembler messages: FATAL: can't create apphello.o: 权限不够 make[2]: *** [apphello.o] Error 1 make[2]: Leaving directory `/home/fzh/uClinux-dist-test/user/apphello' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/fzh/uClinux-dist-test/user' make: *** [subdirs] Error 1 [fzh@localhost uClinux-dist-test]$ =========================================== this is the simple application program:# include <stdio.h> int main() { int i; while(1) { printf("Hello World application\n"); for(i=0;i<2000;i++); } } makefile: EXEC = apphello OBJS = apphello.o CFLAGS += -I. all: $(EXEC) $(EXEC): $(OBJS) $(CC) $(LDFLAGS) -o $@ $(OBJS) $(LDLIBS) romfs: $(ROMFSINST) /bin/$(EXEC) clean: -rm -f $(EXEC) *.elf *.gdb *.o user/makefile: dir_$(CONFIG_USER_APPHELLO) += apphello in config/config.in: bool 'apphello' CONFIG_USER_APPHELLO1 Reply
CONFIG_USER_APPHELLO => CONFIG_USER_APPHELLO_APPHELLO
