a question of download
Assume there are helloworld.c uart.c receive.c and so on.Now,I want to download them to flash,how to do it?Begin,I think I can only download a .srec to flash.In the end ,I found It can download several *.srec to flash.How to do it?
Need a little more info.
If you're using NIOS II they have provided a flash programmer in the new IDE. If you use NIOS I then someone here can give you a hand (never don't it myself). - Altera_Forum
--- Quote Start --- originally posted by badomen@Aug 19 2004, 06:48 AM need a little more info.if you're using nios ii they have provided a flash programmer in the new ide. if you use nios i then someone here can give you a hand (never don't it myself). --- Quote End --- I use NIOS I,please give me the more information.
On the altera site I think there is a flash "bootloader" document. That should give you a pretty good idea of how to do it.
It sounds like those three .c files are all part of one project correct? When they are built using nios-build in the Nios SDK, it should create one .srec file that represents the entire program, say for instance hello_world_complete.srec. Using the srec2flash utility you can convert that .srec to a .flash file. Running nios-run on the resulting .flash file programs it into flash. The GERMS monitor running on Nios handles all the flash programming details.
It sounds like those three .c files are all part of one project correct? Yes ,It is.When they are built using nios-build in the Nios SDK, it should create one .srec file that represents the entire program, say for instance hello_world_complete.srec. Why it should create one .srec file that represents the entire program.I don't think so.I mean how to download several .flash files to the ext_flash.Let me see a flash "bootloader" document on the altera web site.
Not sure what that was about.
Have you searched this forum yet (downloading to flash is a common topic here) - Altera_Forum
I have searched on this forum.But I did not get any useful information.If you know how to do it?Please give me a hand?
Good luck and godspeed.
