21 years agoA question about sram vs. sdram
Hi all, Recently I have been thinking about a question. As we know,without a sram,Nios can run normally; but if the system comes with a sdram and also a sram, what would be the c...
21 years agoMany thanks to cetic and BadOmen http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
But it dawned on me that according to your suggestions, a system with a RTOS(such as uC/OSII) would work only based on a SDRAM without using a SRAM,am I right? Just because the capacity of a SRAM is much smaller than a SDRAM, so if I use a SRAM to run a RTOS,there might be some potential problems with the size of this SRAM.So at this moment,I can only use a SDRAM (maybe work together with the SRAM,but maybe not) to solve these pending problems,right? Regards, Don
