21 years agoA question about sram vs. sdram
Hi all, Recently I have been thinking about a question. As we know,without a sram,Nios can run normally; but if the system comes with a sdram and also a sram, what would be the c...
21 years agoBoth RAM types are on the development boards so that users can design with either. Depending on the end product and implementation one is more suitable (SDRAM is cheap and less power consuming, whereas SRAM is fast and more power consuming). Usually you can get around the fact that SDRAM is slower by using a big cache size and programming your code in such a way that it will not be hindered by the SDRAM performance as much. If you look at timing diagrams for SDRAM and SRAM you'll get a pretty good idea why their performance differs.
