14 years agoA question about SG-DMA in simple socket server example
I run simple socket server example on DE2-115 board. I can't fine the code to initial and use the sgdma(Scatter-Gather DMA) and tse_mac(Triple-Speed Ethernet MegaCore), such as alt_avalon_sgdma_do_sy...
14 years ago --- Quote Start --- The source code is located with the altera ip in the altera installation. The easiest way to locate the relevant code snippets is to use a search engine and look for function names. --- Quote End --- thank you very much!
