20 years agoa problem when run uClinux on DE2 Board
When I do the uCLinux running acording to the http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) I think the tool-chain has be...
20 years ago --- Quote Start --- originally posted by gaobing+jul 6 2006, 04:11 pm--><div class='quotetop'>quote (gaobing @ jul 6 2006, 04:11 pm)</div>
--- quote start ---
<!--quotebegin-hippo@Jul 3 2006, 10:27 AM what is the program address displayed in nios2-download?
if the size of your sdram is smaller that 16mb, eg deii with 8mb sdram, change the link address of the uncompress loader to 5m,
processor type and features-->(0x00500000) link address offset for booting.
the zimage load address is ( your sdram base address + link address offset ) . the zimage boot loader does not relocate itself.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16613)
--- quote end ---
--- Quote End --- Thanks to your reply,I have successful start uClinux on the DE2. But I found a problem when I turn on the series support on the menuconfig: I can the run uCLinux neither from the SDK shell(nios2-terminal) nor the super terminal (windows). Can you help me? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16682)</div> [/b] --- Quote End --- if you want to use serial uart (with a 9-pin RS-232C cable) on a terminal emulator such as minicom or ckermit, (or hyper terminal on windows) in kernel menuconfig, drivers-->char-->serial--> [*] Nios serial support [*] Support for console on Nios UART [ ] Altera JTAG UART support [ ] Support for console on Altera JTAG UART
