20 years ago
a problem when i build my project
my program:#include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# define ccomm 0x00;# define cdata 0x01;
void init_lcd(void);
void write_lcd(alt_u8 data_comm,alt_u8 content);
void clk_busy(void);
void delay(alt_u8 us);
void disp(void);
void busy_check(void);
alt_u8 ch_busy;
alt_u8 data_disp[33]=
0x02,0x00,0x01,0x08,0x7F,0xFC,0x00,0x00,0x00,0x00,0x1F,0xF0,0x10,0x10,0x10,0x10,
0x1F,0xF0,0x01,0x00,0x09,0x30,0x19,0x18,0x31,0x0C,0x41,0x08,0x05,0x00,0x02,0x00
int main(void)
init_lcd();
delay(10);
disp();
return (0);
void disp(void)
{ alt_u8 i;
write_lcd(ccomm,0x80);
for(i=0;i<16;i++)
write_lcd(cdata,data_disp);
write_lcd(ccomm,0x90);
for(i=0;i<16;i++)
void init_lcd(void)
IOWR(RS_RW_BASE,0,0x00);
write_lcd(ccomm,0x30);
write_lcd(ccomm,0x01);
write_lcd(ccomm,0x06);
write_lcd(ccomm,0x0c);
void delay(alt_u8 num)
{while(num--)
{alt_u8 check_num;
if(ch_busy)
{for(check_num=10;check_num>0;check_num--)
if(data_comm)
{IOWR(RS_RW_BASE,0,2);
IOWR(LCD_EN_BASE,0,1);
else
{IOWR(RS_RW_BASE,0,0);
IOWR(DATA_BASE,0,content);
delay(10);
IOWR(LCD_EN_BASE,0,0);
else
if(data_comm)
else
delay(10);
alt_u8 temp;
IOWR(RS_RW_BASE,0,1);
temp=IORD(DATA_BASE,0);
ch_busy=temp&0x80;
when i built my project the system hinted following errors :
**** Incremental build of configuration Debug for project lcd ****
make -s all
Compiling hello_world.c...
../hello_world.c: In function `disp&#39;:
../hello_world.c:32: error: parse error before &#39;;&#39; token
../hello_world.c:35: error: parse error before &#39;;&#39; token
../hello_world.c:37: error: parse error before &#39;;&#39; token
../hello_world.c:40: error: parse error before &#39;;&#39; token
../hello_world.c: In function `init_lcd&#39;:
../hello_world.c:46: error: parse error before &#39;;&#39; token
../hello_world.c:47: error: parse error before &#39;;&#39; token
../hello_world.c:48: error: parse error before &#39;;&#39; token
../hello_world.c:49: error: parse error before &#39;;&#39; token
../hello_world.c:99:7: warning: no newline at end of file
make: *** [obj/hello_world.o] Error 1
Build completed
I wanna know how to solve this problem.
thx v much
    Wow, this is a large program listing and it is all jumbled together. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif I tried looking at the code you are writing, however, I couldn&#39;t find anything too obvious.
    Can you provide us with what comes on the line just before line# 32 in the code display? This would help to zero in on the problem. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
    Tnx.
    No line number in your codes, So I cannot find which line is missing ";" or something else.
    You could try removing the ";" from you# define statements e.g.
    # define ccomm 0x00# define cdata 0x01
    Hope this helps
    You HAVe to remove the ";" from your defines. I had the same problem and got almost mad, until i found a "," after define.
    After a# never use a semicolon.
