21 years agoA problem of programming flash...
Hi all, I meet a new problem when programming flash in NiosII IDE. Just because the err popped during regeneration, I removed the epcs_controller from the components list ...
21 years agoThanks Scott!
Sorry, I really didnot mean to keep changing my problem . http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif I got the solution of the first post from Altera's mysupport, and then I made a new target board aimed at programming the epcs_controller.But as you see,the new problem I met is due to the limited size of the EPCS chip. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif From your suggestions, I 'm gonna make another target board aimed at programming the flash instead of the epcs_controller, and I think I should set the reset address of the system to Flash(0x0000), do you think would that work? Many thanks:) Best Regards, Don
