21 years agoa problem of building project in nios2 IDE
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
hello i created a project with the example hello_world, but when i builded the project, it generated errors. c-builder description was as follows: "make -s rebuild Compiling hello_world.c... Linking hello_world_6.elf... /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc-lib/nios2-elf/3.3.3/../../../../nios2-elf/bin/ld: region RAM is full (hello_world_6.elf section .text) /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc-lib/nios2-elf/3.3.3/../../../../nios2-elf/bin/ld: section .text [00000328 -> 0000b5e7] overlaps section .entry [00002000 -> 0000201f] /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc-lib/nios2-elf/3.3.3/../../../../nios2-elf/bin/ld: section .rodata [00000020 -> 0000051f] overlaps section .exceptions [00000020 -> 00000327] /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc-lib/nios2-elf/3.3.3/../../../../nios2-elf/bin/ld: section .rwdata [00000520 -> 00000f9f] overlaps section .text [00000328 -> 0000b5e7] collect2: ld returned 1 exit status make[1]: *** [hello_world_6.elf] Error 1 make: *** [rebuild] Error 2 Build completed " i had tried some way to solve the problem,but didn't success. The corresponding hardware system is consist of cpu, boot_rom, ram, uart. while i used the example "standard" as the hardware system, it could build the project successfully. could you help me with this problem, thank you very much!3 Replies
The answer is there in your error message
<div class='quotetop'>QUOTE </div> --- Quote Start --- region RAM is full[/b] --- Quote End --- Either increase the size of your memory or look at the section on reducing code footprint in the Nios II Software developers handbook. - Altera_Forum
Hi, I am new to Nios2. I have the same problem when using "small"
example. When switching to "standard", it can be compiled successfully. This was a simple "hello_world" appliation for cyclone 1c20. In the "small" example comes with NiosII software, the on-chip-RAM is only 2K. However, the error message said it need ~11KB bigger. So, as mentioned by Rugbyblock, I change the compiler setting to -o3 and set -DALT_USE_SMALL_DRIVERS. It still needs a lot of memory(~9K). So, I have to go back to SOPC to change on-chip-RAM length to 16KB. Then it works. I am not sure whther it is normal that a "hello_world" program needs ~13KB memory. Or I am doing something wrong. If it needs ~13KB RAM, why the "small" example from Altera only set RAM size to 2KB? Thanks for any help. - Altera_Forum
Yes, I would say that's pretty normal. A printf(), which supports floating point, can consume a lot of memory.
Also, you don't have to play around with the hello_world example, so much, to see what options you should choose, though it is educational. There are pre-made "Hello World Small" and "Hello LED" that demonstrate the techniques you can use to reduce your code's footprint. Best Regards, - slacker
