20 years agoa problem in uploading
i created a uCLinux kernel project in NIOS II with microtronics plugin, and it was built successfully. but when i tried to upload it to the board through jtag, the nios terminal show this: "---...
20 years ago --- Quote Start --- originally posted by repa+jul 5 2006, 01:29 pm--><div class='quotetop'>quote (repa @ jul 5 2006, 01:29 pm)</div>
--- quote start ---
<!--quotebegin-rainhawk@Jul 4 2006, 03:45 PM first, thanks for your reply very much~
but i am working on the nios ide 5.1 with sp1. what should i do?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16644)
--- quote end ---
--- Quote End --- Well, switch to 5.0, if you can, just to make sure. If you can't, you have to figure out what the flags for 5.0 flash-programmer are, what they mean and what are their counterparts in 5.1, and change the calls accordingly. But remember, I'm taking educated guesses here http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif so the problem could be originated somewhere else. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16657)</div> [/b] --- Quote End --- thanks again~ but what is the "flags" for 5.0 flash-programmer? how can I figure it out?
