20 years agoa problem in uploading
i created a uCLinux kernel project in NIOS II with microtronics plugin, and it was built successfully. but when i tried to upload it to the board through jtag, the nios terminal show this: "---...
20 years ago --- Quote Start --- originally posted by repa+jul 4 2006, 05:25 pm--><div class='quotetop'>quote (repa @ jul 4 2006, 05:25 pm)</div>
--- quote start ---
<!--quotebegin-rainhawk@Jul 4 2006, 11:23 AM i created a uclinux kernel project in nios ii with microtronics plugin, and it was built successfully.
microtronix linux extensions
version 1.4, built june 20, 2005
(note: only altera-provided flash components will
work, since install.ptf was not found. this will
probably be fine for you.)
the flash programmer has been updated. please see the
documentation for instructions on how to update your command line.
documentation for instructions on how to update your command line."
<snipped some text here.>[/b] what does this mean? thanks. by the way, my board is altera stratix II DSP board. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16641) --- Quote End --- [/b] --- Quote End --- Are you working on which IDE? The Microtronic Linux distro supports 5.0. If you're working on 6.0, it could be that usage of the flash programmer has been changed. So read the instructions carefully and, if you can, make the adjustments to the command line. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16642)</div> [/b] --- Quote End --- first, thanks for your reply very much~ But I am working on the NIOS IDE 5.1 with sp1. What should I do?
