16 years agoa problem about the memory size of onchip memory
How to design the memorysize of the onchip memory? when i was compilating my design , i saw a message "Error: Selected device has 105 RAM location(s) of type M4K. However, the current design ne...
16 years agothank you for your suggest.
I have already solve the problem. I build the Frash memory to solve it. thank you again. --- Quote Start --- The Cyclone II EP2C35 has 105 M4K OnChip memory blocks. Each M4K has 4096 bits + 512 parity bits. Speaking of bytes, each M4K block has 512bytes (no parity), so if you use more than the available memory blocks, your design requires more than 105 x 512 bytes. so you have 3 options. 1. use a bigger fpga if possible 2. reduce the memory usage 3. check the quartus settings, maybe some memory blocks can be swaped to registers. --- Quote End ---
