16 years agoa problem about the memory size of onchip memory
How to design the memorysize of the onchip memory? when i was compilating my design , i saw a message "Error: Selected device has 105 RAM location(s) of type M4K. However, the current design ne...
16 years agoThe Cyclone II EP2C35 has 105 M4K OnChip memory blocks. Each M4K has 4096 bits + 512 parity bits. Speaking of bytes, each M4K block has 512bytes (no parity), so if you use more than the available memory blocks, your design requires more than 105 x 512 bytes.
so you have 3 options. 1. use a bigger fpga if possible 2. reduce the memory usage 3. check the quartus settings, maybe some memory blocks can be swaped to registers.
