19 years agoA problem about running in Nios IDE
Hi, everyone, I met a strange problem. After I complied the project(standard project, I added user logic and assign pins) in Quartus II 5.0 successfully, and download the .sof file into the Alt...
19 years ago --- Quote Start --- originally posted by bluebell_ll@Jan 25 2007, 09:21 PM hi, hugo_liu,
>>or you can adjust the dram clock step by step until it is ok.
i am not quite sure about the dram clock modification. you mean i should do like this, changing the sdram timing parameter in sdram controller component provided by sopc builder, such as cas latency cycles, access time...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20864)
--- quote end ---
--- Quote End --- I suggest that firstly, you only use the standard project to try it. Then you can add your design. If there are some problem in the standard project then you will check your hardware board. To adjust the dram clock is that to adjust your clock phase.
