19 years agoA problem about running in Nios IDE
Hi, everyone, I met a strange problem. After I complied the project(standard project, I added user logic and assign pins) in Quartus II 5.0 successfully, and download the .sof file into the Alt...
19 years agoHi, hugo_liu,
>>Or you can adjust the DRAM clock step by step until it is ok. I am not quite sure about the dram clock modification. You mean I should do like this, changing the sdram timing parameter in sdram controller component provided by SOPC Builder, such as CAS latency cycles, access time...
