21 years agoa problem about memtest
hi all I construct a system including a cpu ,a on_chip_ram(6K), a flash( 1M X 16bit), a tri_state_bridge! I use the project of memtest in nios 5.0! but when I use the run... function, the cons...
21 years agoThis is nothing to do with memory test, this is saying that nios2-download has checked the hardware in your FPGA and it doesn't match what the code is expecting. I suggest you follow one of the tutorials to learn how to program the FPGA.
