21 years agoA problem about making target board...
Hi all, I want to write program into the flash provided on my board.The FPGA chip on the board is Cyclone 1C6Q.When I followed the document of "Nios II Flash Programmer U...
21 years agoThere is another way to solve this problem.
This problem came out because of the lack of the RAM cells. The Jtag component can use the resource of RAM cells instead of LE cells. You can make it using the LE cells, so that the RAM cells can be used by other component. Double click the jtag component in SOPC build, and disable the options.
